Discuss IR temp measurement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Ermintrude
Alreet ladies. Any recommendations?
Been looking at Fluke MT4 and 62. Thinking of 62. Any suggestions my £12 isn't cutting it any more
Ive got an IR temp gun dont use.
Its non descript brand but just as accurate as my expensive one.
Laser guided too
Prefer the tri-spot myself with motion tracking...a bit like the gun on alien vs predator :)
Twin spot ensures you're the correct distance from surface and the beam is only measuring the bit u want
Yeh but tri spot does all that and also measures the angle of the dangle of the gun for the thermal coefficient or the outer radian
You should check out flir thermal camera it's wicked for checking sludge burst pipes, or even concealed pipework. Plus if you demo it at an exhibition where the stall opposite has the tall blonde lady from baxi working on it. You'll find all the hot spots
Had one from on loan. Did some work in his house. They are getting cheaper and cheaper.
Reply to IR temp measurement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
