Discuss Insurance Claim in the Insurance for Plumbers area at UKPlumbersForums.co.uk.
Thread Status:
  1. AlexGas
    AlexGas Plumber GSR
    True. Sod’s law – it’s gonna pop off as soon as you are out of the house.
  2. happyflyer
    happyflyer Guest
    Just a matter of interest, how long was it after he fitted the boiler did the pipe burst, minutes, hours, days,weeks ????
  3. PlumberTiler
    PlumberTiler Guest
    If this was in court a judge would ask if the plumber made the necessary pressure tests as would be expected of a professional plumber. If he did not then I imagine most judges would say that he failed to do his job properly - the customer can not be expected to know about such things. if a plumber can reasonably predict or be aware of such an outcome then it is his duty to avoid it by whatever means. You would need to make the customer sign a disclaimer that if after all reasonable testing there is still a problem, the customer accepts responsibility for any resulting damage. A plumber cannot however exclude negligence.
  4. Avatar
    Avatar Active Member
    The question is - are pressure tests required on this type of installation?
    If it isn't in the building regs then I do not see how a judge would consider pressure testing a responsibility of the plumber.
    Man - sometimes fittings do just pop off, or expire even after normal work, draining down and refilling ect.
    You can't consider that the fault of the guys doing the work.
    Had the owner asked the plumber to pressure test and to check the plumbing system for fault and potential problems then that might be one thing - but they never do in domestic properties now do they!!
    If you have a 60 year old installation that you have not at least checked or upgraded you cannot blame anyone when it fails . . ..
    The plumbing system (central heating system) in question is the property of the owner, and therefore it is their responsibility should anything go wrong . . .
    • Like Like x 2
  5. SafeGasInstall
    SafeGasInstall Plumber GSR
    just want to add to Avatar post : should a plumber put system to operate in up-normal condition and therefore cause the leak then I agree is the plumbers fault
  6. lame plumber
    lame plumber Guest
    you warn the custard that there is a minimal risk of leaks occurring and they agree to work going ahead based on your warning, and the fact additional repairs are extra any leaks are on their insurance in my mind.
    • Like Like x 1
  7. tamz
    tamz Guest
    Better if you get them to sign a disclaimer if you are increasing the pressure LP :wink:
  8. PlumbBobBob
    PlumbBobBob Guest
  9. lame plumber
    lame plumber Guest
    according to the papers, all the custards are making recordings of our convesations now, so no need for disclaimers:)
  10. tamz
    tamz Guest
    I just read that :smile:
  11. Gray0689
    Gray0689 Trusted Plumber GSR
    A telephone conversation can not be used in law if the person that's recording does not tell the other person
  12. Jimbob
    Jimbob GSR
    Depends. We had a leak on an original system, even after it was pressure tested. The insurance company's will battle it out between themselves and will not always have the same outcome. Insurance company's are a nightmare
  13. lame plumber
    lame plumber Guest
    tell that to MI5 :)
  14. Rickster123
    Rickster123 Guest
    I'm slightly worried by your knowledge of the law in this instance Gray!
  15. Gray0689
    Lol my wife is in court a lot with her work
Thread Status:
