Discuss Installation of a new cylinder in Cambridge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
inneedofhelp
Hello,
I need a plumber to install a new cylinder in the next few weeks. Current cylinder is over 15 years old. Need the cylinder to be big enough to provide hot water for kitchen tap, 2 bathroom taps and a shower/bath. Currently there is no hot water pressure in the shower. The new cylinder needs to fix this problem.
Thank you :stooge_curly:
Thanks for the opportunity.
If this job interests you please PM the op direct.
Reply to Installation of a new cylinder in Cambridge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up & made safe for now, have had affected pipe cut & put end caps on. Work required Full bathroom remove old tiles walls and floor. Renew tiling. New...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
