Discuss imperial pipe to metric using compressions? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
obseen16
hi all,
simple question really but does anyone know if you can use a 22mm compression coupling on the old imperial pipe?
i know i can get metric to imperial (22mm x 3/4") couplings in end feed but i cant use one of these fittings on this bit. or can u get these in compression versions?
J
You could use the standard 22mm compression coupling with a imperial olive for the imperial pipe side..
Reply to imperial pipe to metric using compressions? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
