Discuss Identity of toilet fill valve in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Teka
    Teka New Member
    help please in identifying the make of this fill valve, which I need to replace. The side entry pipe and isolation valve are OK (located within the cistern), so I want a compatible item to fit the pipe
    • Like Like x 1
  2. Matchless.plumb
    Matchless.plumb Trusted Plumber
    Why are you not getting one from fluidmaster side entry fill valve with brass shank ?
    • Agree Agree x 2
  3. rpm
    rpm Trusted Plumber
    • Like Like x 1
    • Agree Agree x 1
  4. Teka
    Teka New Member
    Thanks for your message
    Please can you tell me if the Fluidmaster unit would fit into the existing isolation shown in the photo
  5. Matchless.plumb
    Look above @rpm@rpm link
  6. ShaunCorbs
    Looks like 3/8th to me
    On the old valve measure the threads dia if there about 20 mm it's 1/2 smaller 3/8
  7. Teka
    Teka New Member
  8. Teka
    Teka New Member
    I have measure the old unit and the thread portion is 20 mm diameter overall and 35mm long
  9. ShaunCorbs
    Stnd 1/2 then
  10. king of pipes
    A Torpeck side inlet valve would also do the job cheers kop
  11. Teka
    Teka New Member
    Unfortunately the float sticking out on this model will not fit in the cistern.
    (You can see in the photo of this MacDee compact concealed cistern that there is little room)
  12. Teka
    Teka New Member
    have another fitting in the shed with packaging saying 1/2" and can confirm that the nut from the failure unit fits
  13. rpm
    rpm Trusted Plumber
    Personally I dislike Torbeck valves.
    • Agree Agree x 3
  14. rpm
    rpm Trusted Plumber
    • Like Like x 1
  15. Michael1960
    Michael1960 Plumber
    I reckon on a 3 out of 10 failure rate within 12 months on the standard plasic sidefill Torbeck, I lobbed our £17 for a fancy brass shank one and had a call back a couple of months in, I hate the damn things!
Loading...
Similar Threads - Identity toilet fill Forum Date
Cannot find toilet seats with 270mm gap between hinges? Plumbing Forum Feb 11, 2018
Another toilet bodge Plumbing Forum Feb 3, 2018
