Discuss Ideal Logic Plus 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
merv
Hi, I attended a Ideal Logic Plus 24 today and although there was no fault code, the DHW was reaching a max of 52 degrees. Looking at the service book it doesn't have a DHW thermistor. Can anyone please tell me what regulates the temperature? Thanks
Did you have the tap open fully? I'd say with the tap wide open on a 24kw boiler at this time of year 52 degrees would be quite normal? Try slowing the flow from the tap to see if you get an increase in temperature.
Reply to Ideal Logic Plus 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
