Discuss Ideal Logic gas valve fault in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
  1. Nico
    Nico GSR
    Hi guys came across a strange one today and was wondering if anyone could shed some light cheers.
    Had a report of noise coming from boiler. Arrived on site and found when gas valve modulated to minimum rate it the diaphragm would vibrate and sounded like the titanic was arriving through the front door. Changed out the gas valve but has same issue with new gas valve. On minimum rate I was get 21mbar at test point. Check Venturi which was clean and check burner for debris. Tried a fan to see is the gas/air ratio wasn’t mixing correctly but still had same issue.
    Anyone had anything similar before?
    Cheers for getting back to me
  2. Riley
    Riley Plumber GSR
    If you’re gas safe contact a mod and they’ll let you in the gas safe section
  3. Nico
    Nico GSR
    Sorry just new to this forum so still tryin to figure out how to work it
  4. Riley
    Riley Plumber GSR
    That's cool no worries Shaun will likely be along soon he can help you out
  5. Nico
    Nico GSR
    Much appreciated mate. Thanks for the help
  6. ShaunCorbs
    hello
    • Like Like x 1
  7. Nico
    Nico GSR
    Hi Shaun,
    I am new to this forum and have posted on this public section not knowing there was a private GSR section. How is it you go about being accepted into that section?
    Cheers
  8. ShaunCorbs
    send us your gas safe reg no and i will sort it
Loading...
Similar Threads - Ideal Logic valve Forum Date
Ideal Logic Combi 24 problem Gas Safe Register Forum - Public Forum May 30, 2018
Ideal isar 30HE Leak from DHW outlet? Gas Safe Registered Plumbers Only Jun 16, 2018
