Discuss Ideal logic boiler question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chrisnewton
Hi all
I have had a ideal logic plus boiler for over 2 years now and it's been perfect.
I have had it serviced every year and the book has been signed and dated etc so it's all OK. The problem is that last time it was serviced the guy has forgot to reset the date on the boiler and now it's coming up with 12 month service interval on the display.
I know I should get the guy back out to reset it but is there any easy way of doing it myself?
Many thanks
Reply to Ideal logic boiler question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone else come across this situation? I keep detecting products of combustion inside the casing of Ideal Logic boilers. I've replaced every seal I can find, namely flue seals, turret seals, sump connection seals, burner seal, electrode seal, flame detection seal, etc, and yet still I pick...
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when the Gledhill controls for the “hot water” and “central heading” are turned on the Ideal boiler makes a constant “clicking” noise and tries to start...
J
Turned the system from hot water only, to hot water and central heating the other day. After it working briefly, it has now stopped all together. The display isnt showing a fault or anything - it is just blank. After reading the service guide that came with it - I am confident there is power...
James Middleton
J
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I refilled the pressure using the filling loop, up to about 1bar which is where it usually is, which worked fine, had hot water all day. Same thing...
1K
F
Hi, We have a new Ideal Logic Combi 30. A radiator today came off the wall and developed a leak. Plumber came and fixed (but didn't). At that time the boiler was fine. Today the boiler has lost pressure. I have followed the videos on yt and nothing works. Just stays telling me F1. I have...
FrankMcg
F
