Discuss How to use a u gauge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
cardiff
is there a site where i can get a detailed instruction of how to do a test with a u gauge after fitting a replacement built in gas oven
thanks
Utube whats wrong with a lighter or a match? JOKING IM JOKING please dont do this or mess with gas its not worth it.
It beggars belief. Horrible thing is he's probably got his answer somewhere on the internet and will be up in the morning doing his illegal gas work, quite unaware of the dangers.
Reply to How to use a u gauge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Zanussi gas oven has 4 gas rings and 2 gas ovens (the smaller top oven has a grill). (Model ZCG664GNC). There are 6 gas knobs (gas taps you might say) on the front panel, and one of these has a double function (turn it left and it operates the smaller oven, turn it right and it operates the...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve gauge was going up when the water tank was switched on. My local plumber came and re-pressured the expansion vessel as it was flat, afterwards we tested...
I'm building a steam punk clock and am using a thermometer pressure gauge as one of the parts. What I need to know is how can I plumb to the rod extending from the pressure gauge without using several parts. The rod diameter is 12mm and I will be using 8mm copper piping for the project...
Paul Alone
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hi, I have a PRV located in a heated plant room that is between a pair of stop cocks. It was installed to keep pressure under 3 Bar a couple of years ago but I have noticed an area of verdigris on the piece from the main body to the gauge. I wondered if this might be sign of a leak / trouble or...
