Discuss How to connect dishwasher to washing machine inlet/outlet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jules Humphrey
Hi all. I have a tiny kitchen and want to fit a tabletop dishwasher to the existing washing machine plumbing. I think I have found the right thing to connect the cold water supply - it's called a compression alliance t bar from screwfix and I've attached a photo (hopefully).
However I am a loss how to connect the waste water. I have trawled the internet for hours to no avail. I currently have a vertical white pipe that the washing machine grey hose just sits in - it isn't secured.
I would be very grateful if someone could point me in the right direction.
just push d/w waste into same pipe thats enough slightly tight squeeze though.
Hi , Buy a double spigot adaptor,, which will fit on your waste pipe,, and connect both appliances waste pipes,, google double spigot,, made by mcalpine.. a good plumbing merchants will have one ))
Merchants by me only keep the full kit not the adaptor but the kit is only ÂŁ11
Thank you to everyone that replied. I bought a McAlpine appliance trap with a single spigot to fit the dishwasher waste pipe to and a brass Y adaptor to fit both dishwasher and washing machine inlet hoses to (the t bar connector didn't fit)
Didn't need a plumber at all :)
It`s always good to hear back with good news Jules.
Reply to How to connect dishwasher to washing machine inlet/outlet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
My mum is trying to connect a washing machine and dishwasher in her kitchen. She got a guy out to do the job and he ended up making a hole in her washing machine hose and ramming the dishwasher hose into it, held together with masking tape and charged her 200 quid for the privilege of her...
I have moved our washing machine into the garage but there isn’t a drain for the waste pipe. The attached image is of the waste pipe with the condensate pipe from the boiler, can I use a tee join and connect the washing machine pipe? The pipe leads outside and is saddled to the main waste pipe.
A few months ago I wanted to connect a 1000l water butt (fabricated from galv steel) to our washing machine. After trawling many forums and websites for advice the general consensus was don't bother. I like a challenge so connected up the butt initially with nothing else in line, the washer...
Hello I have ran my washing machine through the autoclean - i have added special detergent like Dr Beckmann yet still have bad smell from washing machine - i have also drained the water that sits in the bottom - any ideas? Could it be a piping issue? Many thanks!
Hi My washing machine is 5m away from the water mains copper pipe/valve. I've currently got a long blue inlet hose connecting the washing machine to the copper pipe/valve. Is this OK or should I get more copper pipe added and then use a shorter blue in let hose to connect the 2?
