Discuss Hot water solar losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
alexmiles
Losing presure from 1.5 bar to zero in a few days. Cannot see any leaks but the pressure release valve in on the roof 50 feet up so I will scaffolders in. The expansion vessel is set to 1.5 bar and this appears to be ok.
Can anyone advise why this might be the case ?
Many thanks
Can you see any stains on tiles from the ground or neighbours property?
If you have a feel around all the joints, be very careful the pipes can get very hot . A leak can show as a sticky mess around a joint. Also you can leave a newspaper or rags under all the joints for a couple of days and you may see stains indicating the leak.
Good look finding the leak.
Had to get someone in to fill it up with anti-freeze. The filler was very inexpensive to I we got someone in. They reported no leaks. I was of thought as it loses around 2 litres in a few days I was expect to see any leaks. Can only assume its blowing out at the pressure release valve on the roof. (can't see any sign of leasks with binos). As the exppansion vessel appears to be working OK why would it blow out ?
sorry dont know if this will help ,today went to a job where the shredded valve did leak like 1mbar for 1 min , could it be this !!!
The PRV shouldn't be on the roof,it should be inside somewhere,I make sure they discharge into an empty fluid container. There may be an AAV on the roof which could be leaking.. I would have filled it with water to check for leaks before putting the fluid in personally.
Thanks for everyones input. I will have to erect scaffold to investigate furthur.
Reply to Hot water solar losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Low hot water pressure Hi everyone, I'm hoping someone is able to shed some light on my situation before I have to call out the professionals. We've been in our house for over 3 years now, when we moved in the hot water pressure was pretty good (confirmed by a retired plumber family friend)...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this could be as a result of us noticing the sound more when there is less environmental noise). Unfortunately, it is severely disrupting our sleep, so we...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed gas could be burned with a blue flame and the water was acidic (pH 5.5). Since then system has been chemically flushed (it was not too bad) and the...
