Discuss Hot tap no water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
karlhayes
my hot tap in the bathroom will turn but no water will come out all other taps both h&c all work fine any ideas please ?
seized tap maybe..shut the water, remove valve body and check if is working as it should. It could be a blockage too but i think you would get at least some drip from it.
If it's a BS5412 valve, i.e not rising spindle then once you remove the head, check to see if you have the circlip still stuck on the spindle.
On the old design taps that are basically a screw that moves a washer up & down, then washer could be stuck, - renew it.
If it is more modern design then it could still be washer, but also could be works disconnected. As said, check circlip, but could be the common problem of wear on the O rings inside the works, that means water enters into the part the threaded bit goes. This is often on hot taps due to heat. Remove the works, take clip off, ( the works are in 3 parts), tap spindle out, screw spindle apart, & as you probably won't be able to match the O rings exactly, just clean & grease with Vaseline or silicone grease, & put together & refit. May last reasonably well. If you could get a new spindle with same splines to suit tap head, then often better a new one.
If the taps are just ordinary standard BS1010 turning on/off taps, you'll probably find the spindle (which has a left hand thread) has probably come loose in the tap body and stuck down..Just as galaxy has said and dont forget to replace the rubber washer.. Good Luck PaL
Reply to Hot tap no water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the mains water, turned boiler off (Remeha avanta) and opened the hot kitchen tap to drain the cylinder. After doing the work etc, Everything up and...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a megaflo unvented indirect cylinder (125i) boiler is a Worcester greenstar. I have good pressure on the cold feed and all the usual stuff works, taps...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
