Discuss Hot/Cold water outlets in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hello! Hope i'm the right part of the forum. I got a washing machine recently and now i got the problem that there's no way of telling which one is the cold water supply as the machine only needs cold water. The pipes are not marked with blue or red so my question is, is there any other way of telling which one is which?
Thanks a lot for any help!
Reply to Hot/Cold water outlets in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine waste but the problem is in the water supply. Currently there is only hot and cold washing machine hose fitting isolators attached to very short...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume...
Hi, I’m having issues with cold water to multiple outlets. Taps, showers, toilets cold water is fine at the kitchen sink. The hot water system is a Glenhill unvented cylinder. Hot water is fine at all outlets. I assumed the cold outlets not working were from the balanced cold from the...
2K
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a steady stream without stopping. Seems to be coming from water heater but I cannot tell. It is cold water. When I turn off the main water supply, it...
Pritesh Patel
Hello, We hade a problem with our hot water not working in one of our bathroom's (all other outlets were working) Therefore we got the Thermostatic Shower Valve changed and everything was working again. However a few days later, both hot and cold no longer works for the bath and the hot...
