Discuss Hot blow torch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stani
Subscribed
There was a thread a while ago regarding a blow torch, just seen it in Stax (for those that have one near them) £25-99 +vat
Look's o.k and a good price anyone used one?.....regards Turnpin:D
The only downside at the moment I can see is max op temp 1630 c when mapp runs around 2/2300 c
Propane also burns in air at a little less than 2000c, forgive me but I don't quite see the point of that operating temp warning especially when they have a plastic bodied piezo sitting quite near the tip.
Did they have any similar torches without the piezo?
No that was the only type, I might get one as a spare, my sf2 is good but anything happens I'd be lost. So might be worthwhile just keeping it.
Worth it I think, I've used one before and as you hold the gas bottle I found them far easier to handle than our gun style torches like the Roth.
If you're going to get a budget spare you won't do much better than the £40 from 'stool'station. I've been using it 6 months and really like it.
It's a Bullfinch under a different name as far as I can make out.
This one.
ezo Ignition Turbo Torch
Catalogue p117
Catalogue 117Piezo Ignition Turbo Torch
Uses MAP-Plus or propane gas, 71066 or 13125 with self-lighting piezo ignition. Ideal for most soldering applications. High performance adjustable turbo action flame with safety lock to prevent accidental ignition and button lock for continuous use.
Code For delivery
36574Piezo Ignition Turbo Torch 24 Each
£39.81
£33.17 ex.
Remove
Reply to Hot blow torch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, my wife decided she wanted new modern bathtaps instead of the old 'supertaps' we've had since we bought the place. So we bought the new taps and I tried fitting them yesterday but the new taps don't have the same fitting length as the old ones, this wasn't aproblem on the hot supply as...
Deleted member 120897
Hi I've seen a previous thread that is closed now regarding this subject but the end result I could not see. Our Shower runs hot for 30 seconds then cold. I have changed the thermostat and it still runs cold after 30 seconds. If we run the hot tap it is better but at best, luke warm. We have a...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work. The builder got him out again and he created a separate heating circuit from the boiler (ie one circuit for the house, the other for the extension)...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't compatible with the new universal one, but the wiring was pretty close AFAICT (N, L, 1, 3 & 4 connected) .When I first powered it up but didn't have any TRVs...
