Discuss Horizontal solar cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Megaflo-Experts
Can anyone recommend a decent twin coil horizontal unvented cylinder, suitable for solar and a gas boiler?
It needs to go in the loft space and therefore needs to be a horizontal cylinder.
Have seen some Thermsaver cylinders online and they look ok - anyone have experience of these?
RM Solar made one for a customer of mine last month. I think it was a custom build - it certainly wasn't cheap.
Haven't had any feedback, but could ask if you like? No experience of the the Thermsaver - sorry.
Thanks for that Ray. I'll have a look at those online; I think most of them are custom made - I believe the Thermsaver ones are.
McDonald engineering in Glenrothes Fife make anything you want, great turnaround service
Thanks for your help and advice guys. I'll make a few calls, and it looks like it they are made to order!
Thats true. I needed a 42 x 18 gravity twin coil a few weeks back. Ordered it on the tuesday afternoon and picked it up and fitted on thursday morning.
Scrappies heaven that place :lol:
Reply to Horizontal solar cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just looking at getting an unvented cylinder. Screwfix do an RM cylinder called Prostel. Anybody had experience with these. ÂŁ830 for 250l horizontal.
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element required). This means that I have a 2.5 year old StainlessLITE Plus Horizontal unvented mains pressure 204L cylinder left over. We had it installed in Jan...
Peter M
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future, but likely the PV kind rather than the thermal kind, and won't be having heat pump in the future. So the cylinder would be connected to the boiler at...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the immersion heater. Just wondering if there are any devices that can circulate the hot water in the cylinder so the immersion heater heats all the water...
So after having engineer drawings back I'm limited to around 90cm of loft height. I was thinking of a preplumbed horizontal cylinder. But now wondering if a pump and zone valves on the landing in a separate cupboard with just the cylinder flow return going to the loft. Is this an ok idea of...
