Discuss honywell 3 port valve running hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Jacks
just replaced the motor because it was getting hot , new one does the same is this normal, as far as I can work out the motor has to keep running to keep the valve open because of the return spring, is this right, valve works okay with the motor or with the manual lever.
Reply to honywell 3 port valve running hot in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
I have an old Potterton suprima boiler with a hot water tank and pump. We have hot water but no heating, the light on the boiler is showing amber (no call to heat) I have been told that this is likely due to the 3 way valve or motor on it (Myson Power Extra). I am wondering whether to try and...
2K
Hi. I replaced the Pressure and Temperature relief valve on my MegaFlo CL300 (I had thought it was dripping but it turns out the overflow drip is coming from the 3bar safety relief valve for the red expansion vessel) Before I replaced the valve it would recharge the air bubble normally - the...
My 3 way actuator valve has gone on my central heating. I think it's a combination of the valve motor burning out due to a stiff valve on the pipework. I'm considering doing the fix myself but wanted to check I know what I'm doing beforehand or whether I should get a plumber in, have I missed...
1K
