Discuss Honeywell gas valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
solutions
Need a honeywell vk4105m 5132 4 gas valve for a ferroli domicondens f28 can anyone on here tell me if the valve differs from the core vk4105m and do the trailing 5 numbers indicate the difference. Essentialy can any vk4105m be used as long as tge connectors/ pipe unions are retained from the existing faulty valve?
If you contact ferroli they should be able to direct you. I know Honeywell have an app called Honeywell installer assistant but that's just for controls I think. Might be worth a look all the same
Reply to Honeywell gas valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
