Currently reading:
honey well motorised valve without a manual lever
Discuss honey well motorised valve without a manual lever in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
As anyone came across a motorised valve without the manual lever? I had one with was a honey well 28 mm the merchant said it's for back boilers and they open up when a power cut has occurred. They are hard wired in.
Can someone explain there purpose and where there location is on a heating system.
Great thanks too you all.
Normally open valves that power close, so in a power cut they will remain open and be safe. Usually ive seen on solid fuel installations.
They allow gravity circulation on a solid fuel system to a circuit in the event of a power cut to let the excess heat go somewhere. Depends on the design of the system. I will see if I can find an example
You will have a power closed, normally open, on your heat leak rads and a power open, normally closed, on your cylinder. Power cut = fails safe.
I don't understand what you mean. The heat leak rad will have the zone valve on it and we'd only open when power cut happens. How does it get warm when there isn't a power cut?
If there's a solid fuel stove boiler, it'll carry-on burning etc
Where there's and uncontrollable heat source, solid fuel, the circulating pump will move the heat to Rads or cylinder in normal circumstances.
Control of those circuits (or part of for heat leak)will be with a Normally open, powered closed (no lever to fix it closed) Valve.
To close the valve the thermostat puts power to it unlike a normal valve where it takes the power off.
In the event of a power cut, the valve opens and gravity circulation takes place.
This couldn't happen if the valve was a normal powered open valve.
Can someone show a diagram of location of this type of motorised valve. Chers
It opens once cylinder is up to temperature.
Honeywell zone valve as no lever. I want to understand its function and how it works in a gravity heating system. As this type of valve only opens up if there's a power cut and the back boiler was on as this would dirvert the heat through a loop eg heat leak radiator. Which i assume that this radiator would never get warm only if there was a power cut. As it would only circulate in Gravity the heat leak would need to be high some where close too the f&e tank. Can someone explain with hands on experience would be great to understand.
Doesnt only open in a power cut, it also opens once the cylinder stat is satisfied.
See post #10
Reply to honey well motorised valve without a manual lever in the Plumbing Jobs | The Job-board area at PlumbersForums.net
