Discuss help please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
persistent king
Hi im Brian mod on the flooring forum, I was wondering if you could give me some advice plz. Ive had a log burner fitted by a guy I thought I could trust but when there was no breeze outside a dreft blew down the flu so I had to open the front door to get the breeze blowing up otherwise when I lit it smoke would blow in my lounge.He told me to warm it with a blow torch to warm it up , so I got a seconed opinion from a company who specialize in fitting them . theyb asked me did I get a certificate and was he hetas registard I asked him the question but he said he was in the plumbing and heating assoc and he could give a certificate because of this and he would give me one that I still haven't received , on the inspection they told me he had gone horizontal 800mm instead of on a 45 diigree there was a pipe joined in the cavity and it wasn't twin lined going through the wall ,there was to many bends in the flue and the harth wasn't deep enough. he came back and took the fire out and I got the harth re done to the correct size but he wont come back to fix the pipework and refit the fire or give me a certificate.i am going to take him to small claimes court but I feel he needs stopping fitting these , so what can I do to report him and who do I report him to as I feel cowboys like this like in my trade need to be stamped out. Regards Brian.
Trading Standards
Local Authority Building Control (they can prosecute him if he has done work which is supposed to be notifiable and hasn't been done in accordance to Building Regs or other standards.
HSE
HETAS (they can only take action if he is registered which he probably isn't).
Unfortunately somebody usually has to die of CO poisoning before any serious action is taken.
ive tried to keepm it brief and short nas I can , there is a lot more he has done wrong but bthe fire is the main one
First port of call for advice would be Trading Standards, then your LABC
Did he fit ventilation and a co detector. HETAS won't be interested as it sounds as though he's not a registered installer. Trading standards or citizens advice as a first port of call.
LABC may want to make an example of him as it's notifiable work not done according to Building Regulations etc.
Whats LABC and HSC and no I had to buy a carbon monoxide alarm after thanks for the replies
he has taken my money and the company that did the inspection said it is unsafe to use
LABC - Local Authority Building Control Dept
HSE - Health and Safety Executive (more dealing with workplace issues but they sometimes get involved with fuel safety issues)
You have a strong case if you can prove in court that the installation is "not fit for purpose". You will need a report from the registered company who inspected it saying so. I would expect that the original installer would be liable for any cost for any remedial work to make the installation conform plus any making good, rather than being made to refund the amount they charged you.
that's fantastic mate thank you very much , I will ring traiding standatds and building controle and HSE tomorrow and see what they say , I have lots of proof he fitted it
Because the work is notifiable, you should have a stronger case than simply for poor workmanship.
The main battle is of course getting the money out of the company once a court judgement has been made in your favour.
A number of LABCs are undertaking a crackdown on rogue tradesmen doing notifiable work at the moment.
[sole] trader. The other is St Peter! (was the punchline in an old joke....)
Joking aside, get someone you know to proof read through any correspondence you have with any organisation or individual regarding this issue to make sure it's all correct as everything needs to be correct and accurate.
he also fitted my bathroom suite the pump isn't strong enough the sink that is fixed to the wall free standing is bent and to low so I cant get a vanity unit small enough and the bath panel on the p shaped bath isn't fitted correctly and water is making it bubble as when you stand in the baqth it drops slightly because he didn't fill it with water before he sealed it and fit my shower screen
You need to get a report done detailing everything not done properly and a cost for putting it right including any making good.
Common bodges (amongst others) to watch out for are the shower tray not sealed properly and plasterboard instead of cement board behind the tiles in the shower.
ask for all you money back from installer , and tell him he has two options money back in full or you on the phone to trading standards
its funny im very attention for detail with flooring and am very good at my job and passionate about flooring so I didn't go for the cheapest like most do , I just trusted him and didn't know anything about hetas etc ... just thought he knew his stuff as you do
why did you not come here before work took place ? we have better plumbers here then that one
Don't accept an offer for him to come back and put it right as he probably doesn't understand what he has done wrong in the first place.
today I rang Building control and didn't get anywere then I rang hse and couldn't speak to anyone so I emailed them, they emailed me back and said id sent it to the wrong department so they had forwarded it to the correct one .Then I rang traiding standards and didn't get anywere eith them , he said he was a member of the plumbing and heating contractors accoc so I rang them and he wasn't bon there system.so I have got no were today .my accountant advised me to get reports on the fire and the bathroom and also quotes to put them right then start court proceedings , any more help would be appreartiated. thanks
I feel like going round and taking his head of his country and western shoulders but I know that's not the answer:cuss::cuss::cuss::cuss:
they said take him to court, surley there is someone I can report him to ? its a joke this he has put my family at risk from danger and there is no one who can stop this cowboy
Trading Standards are usually helpful, keep on at them.
rang them again today if I don't hear anything soon ill write them a letter
this may be a long shot but i was thinking why not write to either david cameron or your local MP but probably better if david cameron. detailing everything as they have to read all mail that comes through they would forward it onto the relevant department and they would be forced to act on it. in theory but its worth a try.
that's a good idea , worth a shot , got quote thru today to put it right ÂŁ850 gulp
Reply to help please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
