T
TRAVELMAN
Hi all,
Please be gentle as not very technical! Was given the above by a friend (only been used 3 times!)...all plumbed in fline. Did my 1st load on economy (no 2) & I've NEVER seen dishes/glasses so clean!
Tried other programmes--number 4 (1 hour programme) & number 5 (rapid) & I get the pre-light & wash buttons staying on towards the end of the cycle (usually when its about to rinse but not too sure) & the machine just stops. According to the manual this error has a meaning of 'longer inlet time (??!) -possible cause is 'faucets is not opened (??!!)....now as long as the economy works I'm bot fussed but it's bugging me as to what might be causing this. The area I live in has about SIX houses using one stopcock so for example the water pressure is so crap that you can't have a strong flow of hot & cold & another example-if you're using sink & flush loo then loo will take AGES to refill-yet as soon as you turn tap off it's fine! I've lived in this area before & it's a common problem on this street. Likewise if other houses nearby are using water then my water speed/pressure drops.
The machine is on cold feed only by the way (& washing machine works fine). I'm wondering if maybe when water pressure drops if others are say runnung a bath it affects machine??
So long as the one programme works I'm happy, but if easy/cheap to fix will have a go! Any ideas anyone?
