Discuss HELP! Can I unscrew towel rad valve? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Richard Skerritt
    Richard Skerritt New Member
    Hi guys
    I have a leak as per pic 1 and looks like new valve is needed.
    Obtained a new one but wary bout unscrewing bottom - pic 2 shows valve, as this feeds straight from the copper pipe which is the water.. I assume I can use stop cock to halt supply, but im more Interested that has a plumber got the tools that's needed to not damage pipework before unscrewing and then screwing new one on which will be sealed correctly? Thanks guy's
  2. king of pipes
    It will need a drain down to change it a pro plumber may be able to lock the system up and swap it but i would not advise you doing it yourself . Cheers kop
  3. 1Steven
    1Steven Plumber GSR
    Yes drain down needed.
  4. Richard Skerritt
    Thanks guy's. This only happened after I removed the rad due to a rawplug coming loose from wall which then got fixed. I was OK removing the top nut to just enable me to empty the rad. But looking again at that slow drip you can see, is a replacement valve the only solution?
    • Agree Agree x 1
  5. Ric2013
    Ric2013 Plumber
    If it isn't dripping more than a drop or two, you might find it will fur up and seize if you are in a hard-water area, particularly once the heating season starts. Then it won't drip any more. Not what I would recommend, but if you are really skint...
  6. Richard Skerritt
    Hi, yes I did think that once the heating was on more it may fur up- but I think the drip is about a medicine syringe measure in about 2/3 days... I have bought a new valve but of course it looks like a Pro Plumber is needed to actually fit it.. :-(
  7. Ric2013
    Ric2013 Plumber
    My feeling is that is probably slow enough to fur up. And yes, agree with others you will need a plumber to fit the new valve.
Loading...
Similar Threads - HELP unscrew towel Forum Date
Help choosing lpg/oil/biomass please! Central Heating Forum Today at 9:08 AM
Brand New To Forum Hoping For Help Valves & Taps Yesterday at 6:57 PM
