Discuss Hand cleaning and care in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all hope you are all ok, my hand seem to be gathering crud in the creases on my finger's and I was wondering what you lot use to keep them clean and smooth. Is swarfega still the best or is there a new king of handcare?
Merry Christmas, Dave
i use swarfega, ive got one of these in the back of the van, Swarfega Hand Care System Dispenser | Hand Cleansers | NoLinkingToThis
a squirt of cleaner when i go the van for something and the hand cream if my hands feel dry
stick some silver sand in the swarfega, or a pinch onto your hand. it will clean 10x better
I use a scouring pad with normal soap in the shower. Deals with the rough skin at the same time.
Then a dab of norwegian formula hand cream. The skin on my hands is tough as old boots but you wouldn't think it if you saw or touched them.
i didnt get the crab bit?
norway stuff is very good stuff for slit hands etc
Nail brush in the shower, need 3 or 4 days off to get them truly clean :)
After reading a article a few years ago, on what was in hand cleaners etc etc, I stopped using them all together .
I only use soap, but wash them regularly . If they are really @rapped up a small amount of washing powder and fairy liquid works for me .
I wear "assembly'' line gloves almost all the time, they are very light weight and nimble enough for our work. They last about a week or two for a couple of quid each they save my hands and the bother of having to deep clean them.
If not a good barrier cream applied for a minute at the beginning of the day will save your hands and time cleaning them, my hands were in poor shape before I started using cream and then gloves.
As with the use of knee-pads, ear-plugs and safety glasses, there is nothing macho about being a cripple when you're older, our work can be hard enough so look after yourselves.
Reply to Hand cleaning and care in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So, in theory, a toilet with integrated bidet (spray wand) sounds like a nice idea. Cleaning with water feels more hygienic, saves paper. But what about practice, can someone with experience tell me: Are you supposed to use them for the full clean, or are you supposed to wipe normally and...
1K
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
Hi, Solar thermal not so big these days but a couple of Q for anyone who still works in it. Background. I'm an Electrician not a plumber.. I've been maintaining my otherwise excellent solar thermal (Original install MCS by Others), for the last ~ 18 years, over which time I've needed to clean...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a lot of installs or a tremendous amount of gas work but obviously when I do undertake these things then I try my best to keep within the appropriate...
