Discuss HALL of LEGENDS photo gallery. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
AlexGas
Subscribed
Let’s show the British people what we can do!
just out of interest, how do you get to the trap on that basin?.
There’s a full access to the trap and ISO’s through the hole. It’s just other side of the tile and 18mm ply. The bottom of the trap is almost in line with the top of the opening.
The panel behind the WC is removable.
Very nice job. Must have a tile table saw for them cuts above the worktop.
Cheers. The worktop comes to the tile and the bottom edge of the skinny tile is within the thickness of the worktop. I’ve used a wet cutter.
Well… The customer has changed her mind 3 times on what to have under the wash basin and by that time I’ve done the most of the tiling. I didn’t really want to have that grout line so close to the worktop but that’s the way it goes. Also I couldn’t really go any higher with the wash basin, I think the top of the wash basin ended up being 850 ish of the floor. I did point the lot to the customer and she was fine with everything.
Beautiful finish, very impressive!
Check the batch numbers on the tile boxes next time though buddy, the vanity unit colours a little different to the wall tiles.
Stay tuned for more crappie jokes! :)
Good job AlexGas.
That’s what the customer wanted. It’s fully removable. What’s wrong with that? I take it you are not big on them.
Not having a go Alex, if you can get it off ok, but every one I go to is nailed on or screwed on LOL .
Nope none required.
There would already be a vent in room fir the bbu wouldnt there. No doubt wallpapered over.....
Whats that beliw the fire? Did you leave a boo-boo or is it a remote sensor? Cant tell from my phone
Remote sensor. What a horrid thing to fit! Thatnis the temp sensor. Mark on wall is nothing to do with fire
OK, hit me! Nearly done... It’s all about the cable, will do it tomorrow…
Reply to HALL of LEGENDS photo gallery. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
