Discuss Guess the amount in the Insurance for Plumbers area at UKPlumbersForums.co.uk.
Thread Status:
  1. lbp plg & htg
    lbp plg & htg Plumber GSR
    Replacing a wall mounted shower/ mixer valve above a bath last week (thurs) and removed old by first isolating cold water into apartment which in turns also stops supply to unvented cylinder.
    As tiler needs to retile wall I put 2 ball o fixes at low level so rest of apartment is allowed to remain in use - no problem.
    Comes back 2 days later to fit pipes through for new shower/ mixer valve and isolates water again and drains excess water to allow two tees to be soldered into pipework dropping from above to supply the mixer.
    In the time time ive got out of the bath to get some pipe and fittings from hallway I've heard water start to gush out and to my horror for some reason the cylinder has started to back syphon upstream of non-return valve and out of the open end Im working on.
    So this water then drips through to the apartment below causing staining on the ceiling. Assures owner that the water leak has stopped and they come upstairs to witness.
    Friday I get an email advising that it has damaged all their wooden flooring and their assessor has already been and they are awaiting the amount to rectify!
    Any guess's how much this will be? Spin the wheel of fortune.
    Leeson learnt - never trust a non-return valve!!!
  2. lame plumber
    lame plumber Guest
    pushfit cap ends rule the day, esp if you are working on a system you havent installed.
  3. Keefy
    Keefy Plumber
    Don't you have PLI?
  4. MRDrip
    MRDrip Member
    New total floor 2 to 3 K
  5. Clokworkheating
    Clokworkheating Guest
    Alway make sure you have pli cost about £600 for me and covers Dom,comm,catering and industrial gas hot works
  6. lbp plg & htg
    Yeah, got it but just frustrates me. Anyone have any experience of claiming and how much it puts your premium up by?
  7. lame plumber
    lame plumber Guest
    ask to see damage yourself and take photos for your insurers asap or get your insurers in now to avoid being scammed. 9 years back I had removed a small grass bank and replaced it with a stubby wall to stop water flooding off the road, just tidier than a muddy wall. 4 months later massive down pour and all the road water shot into neighbours rear access and down through his house (we are on a hillside) and he tried to blame me, assessors sending out claims letters etc. It took me writing a long tome explaining how idiot neighbour had been flooded on previous occassions before i moved in an how he took no avoidance measures for whole thing to quietly go away! they always try it on first!!!!!!!
    • Like Like x 1
  8. plumb
    plumb Guest
    The problem is that they will not repair it on the cheap if the insurer is involved. We could get it done for less than a grand but my guess is that it will come in between 2-3k for a normal room. Premium will go up do you need to offset the increase by searching with other insurers - this could help.
  9. lbp plg & htg
    I understand that if I claim then my premium will go up but what do you mean with regards to "do I need to offset the increase by searching with other insurers"?
  10. plumb
    plumb Guest
    You can usually offset an increased premium by switching to an insurer with a lower premium. I've known friends to claim ona policy and then switch to another company and hardly had any increase even though they had a claim. Just depends on the insurer.
Loading...
Similar Threads - Guess amount Forum Date
I think I can guess what they want Plumbers Arms Jun 30, 2018
Thread Status:
