Discuss Grohe Eurosmart Kitchen Mixer tap removal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
osh
Trying to remove the tap lever on above mentioned mixer, model no. 33281001 and not having any joy.
I've removed the screw cover and the allen grub screw, but nothing seems to budge. I'm assuming it needs to be pulled straight upwards?
Would appreciate any pointers.
Incidentally, the cartridge has become stiffer over the past few days. We live in a very hard water area. Before I shell out most of the cost of a new tap for a new cartridge, would soaking it in descaler help to loosen it up?
Reply to Grohe Eurosmart Kitchen Mixer tap removal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
How do i replace the quarter turn cartridge on this cooke & lewis ricci bath mixer tap . Normally there is a grub screw somewhere to take the handle off, but for the life of me i cannot find one on this mixer. Any helpful suggestions would be greatfully received.
I’m trying to replace a cartridge on a Grohe mixer tap but I can’t get beyond second stage! I have removed the grub screw,but cannot lift off the lever.I have applied some wd40 into the grub screw hole,..but the lever won’t budge. is there any other method for removing the tap lever?…help...
2K
This is driving me bonkers! I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early Florentine model circa 2006 though not 100% sure. I've removed the faceplate, unscrewed the chrome collar - and now want to extract the diverter...
