  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Groaning Pipes: unvented water cylinder in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Rick Webb
    Rick Webb Guest
    Firstly, what a great site, and thanks to all the hard-working and committed professionals who are prepared to take the time to offer advice.
    I have a Range Tribune Unvented Electric Water Heater (with expansion vessel). It was installed approximately 2-3 years ago.
    I recently had a plumber from a large reputable (but local) firm to visit to perform a service. I asked if he had an unvented certificate. As part of the service, I mentioned that the overflow occasionally leaked.
    He checked the expansion vessel and the pressure was low. He restored the pressure to 3 bar.
    After he had done this, the pipes started making an awful groaning sound every time the hot water was turned on, especially after the water heater is on. This lasts between 30-90 seconds.
    After one week, the noise had not stopped, we called the plumber who came back out. He reduced the pressure in the expansion vessel to about 75% of what it should have been. He explained that if that didn’t fix it, the expansion vessel was probably faulty.
    I have taken a video of the noise it makes:
    http://www.youtube.com/watch?v=WuQuT7deA78
    Given that the unit is less than 3 years old, and this problem had never existed before the plumber came out to it, I struggle with the notion that this is a faulty part.
    Is there anything else this could be?
    Any advice/help would be appreciated.
  2. cr0ft
    cr0ft Trusted Plumber GSR
    Hi, has the unit been serviced annually or is this the first time it's been serviced?
  3. Rick Webb
    Rick Webb Guest
    This is the second service, and the unit is perhaps 3 years old. It has been serviced almost annually.
  4. Rick Webb
    Rick Webb Guest
    After help from the Webmaster, I have been able to edit this post and include the link to the video (if this helps).
  5. stoker122
    stoker122 Guest
    I had a similar problem after servicing an unvented cylinder once, turned out to be a problem with the pressure reducing valve juddering, water hammer type thing.
    We had to change it.
Loading...
Similar Threads - Groaning Pipes unvented Forum Date
Heatline Vizo 24 groaning noise Gas Safe Registered Plumbers Only Feb 13, 2016
Heatline Vizo loud groaning noise Gas Safe Registered Plumbers Only Feb 12, 2016
Heatline Vizo 24 - loud groaning noise Plumbing Forum Feb 12, 2016
Kopex Pipeslice which to go for? Plumbing Forum Monday at 9:41 PM
King of Pipes gets Trusted Advisor Badge Links, Forum Updates, News and Site Suggestions Jul 11, 2017
advice on moving pipes for power shower Bathrooms, Showers and Wetrooms Jun 22, 2017
Banging pipes problem Plumbing Forum Jun 19, 2017
