Discuss Greenstar Utility 32/50 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
withdrawing my offer to turn out, you seem to know what your doing!
I know my limitations - I can find info on the internet well but I'm not a qualified oil technician!
Interesting - any way of telling whether I've got the old or new design of blast tube, short of disassembly, and are WB doing it as a recall/warranty item, or is it a matter of buying one, part no 87161080790 Blast Tube type S looks like the right one.
The modified one has a hole drilled in it whereas the original didn't. There's no recall, they're just changing at as there are issues.
ÂŁ18 for a flexi seems a bit steep unless it's the long life type (which I would request).
Everyone's overheads and profit margins are different, also might be buying from a supplier who is charging big for quality.
I totally agree with some of the above, ill set a boiler up as close to MI as poss then over air it slightly to avoid sooting. As above, you lose a small amount of efficiency but are mostly assured a cleaner burn. Anyone trying to set and retain Manu spec on an old boiler is daft in my books!
Reply to Greenstar Utility 32/50 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
