Discuss Grant lwp switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Billy Bob Bob
Anyone help me out with a part number for a CH LWP switch for a grant combi 90 v3,cant find it on HWOS site
Try heating world of spares. Fitted one last week. Plastic tat. I'm out or could give you the part no. Eighteen pounds something.
Thats the one. Pile of poop. Shears off and you have to hammer a screwdriver in to get the threaded bit out.
Expensive that one.
Expensive that one.
same as the worcester flow switch that some how always springs a leak on the threads
Reply to Grant lwp switch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting,. So I have set all the little timer switches to ON and the boiler does work then. Any help or source for a new clock would be great. TIA
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes...
Hi all I have a britony combi se 80 with fault 40 60 80 had british gas out to repair under homecare cover but they can't seem to repair it. They have been out 7 times so far and fitted a new pump heat exchanger air pressure switch and a pcb. Does anyone on here know what else could be the...
Following on from my question about monitoring F & R temperatures, I needed a measuring device because the overheat stat. frequently trips and then needs to be reset. It normally happens when the boiler has switched off and is no doubt due to the hot water rising to the top of the boiler, but I...
1K
