Discuss GRANT Air Source Heat Pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
No I don't but there is not much to see from outside and would need rather a large memory card to photograph the entire installation it's a big place....
On another note I evaluated a install in kidderminster. Long story short 30W per square meter was calculated for the heat output which would not have been too far wrong exept for 3.6m room height throughout the whole building plus a massive amount of glazing on the first floor and second floor and nearly half of the roof.
My report to the specifier was entertaining.
sounds like you need soft start fitting my boss had one fitted at a cost of ÂŁ250
no news they were meant to have done it three weeks ago but nowt happened will ask and see whats going on with it. think in my earlyer post the price is wrong wasnt particularly listening was about 7pm on a friday :26:
can the air source be staggered somehow so they dont start at exactly the same time?
Reply to GRANT Air Source Heat Pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Hi Can somebody tell me if a standard heat source pump installation uses a pressurized hot water tank? Or will the pressure for the hot water be the same as with my oil boiler and water storage tank (gravity-fed)?
Hi, Short version: Do frost protection valves trigger when the water in the pipe gets to threshold, or when the air temp drops? Long version: I'd rather use frost protection + anti-freeze cycle on my mitsubishi ecodan heat pump. The warranty is apparently fine with that combination, and it...
I'm planning to get an air source heat pump (ASHP) installed and I'm considering my options about the location of the water cylinder as I live in a small house and space is a premium. I was thinking about building a small insulated shed about 20 to 25 metres away from the house to put the...
2K
hi everybody i need some help please, i can't remember how to adjust the temperature setting in heat mode on my dream air source heat pump does anyone know the sequence please? any information would be much appreciated .
2K
Mike marks
M
C
Do you have some experience with Air Source Heat Pumps and are looking for your next role? Evergreen Energy are hiring for a Commissioning Engineer in North Yorkshire now! Please pm Cecile
Cecile
C
