Discuss good 18v cordless? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
zackb
hi all,
any recommendations on a good cordless 18v drill within a bugdet of £90?
the one i have now just cant do the job anymore lol
thanks
zack
on that budget you will struggle a bit.
the new ryobi stuff isnt bad at all though and will probably be around 90 quid.
either that or start saving
Milwaukee fuel all the way. out of your budget but are a hell of a lot cheaper when bought from America r
Do you have other cordless gear, if your batteries are ok try finding a bare unit that takes your other batteries that may help in that price range.
Dozens to chose from at that price but you will have to sacrifice something. ie. one battery, lower Ah battery's.
This is a great buy:
Hitachi DV18DSFL/JC 18V 1.5Ah Li-lon Cordless Combi Drill | Cordless Combi Drills | NoLinkingToThis
True, if you up your budget a bit you can go Makita
Makita DHP453RFW 18V 3.0Ah Li-Ion Cordless LXT Combi Drill | Cordless Combi Drills | NoLinkingToThis
where I suppose a 3A bat will last twice as long as a 1.5A.
3Ah battery will last twice as long on a charge as a 1.5Ah, but I would prefer to have two of 1.5Ah batteries as only one 3Ah battery. That way I have lighter batteries & always one fully charged, yet same power & run time overall.
My brother has the Hitachi Combi drill for DIY use, but I wouldn't rate it much. It cuts out if you work it hard & it's a bit bulky. But to be fair, it is a very decent drill for the money, but it is not a pro drill. The Bosch combi drill from Screwfix with 2 of 2Ah batteries for £150 has good torque & nice & compact size.
I agree that two batteries are preferable but my reasoning is it starts him on a far superior platform and if he want's to buy an impact driver, SDS or even just another battery he can do so at a later date when he has or is willing to spend more money. Tbh mate I don't think Ive never seen a Makita 18v Combi with 2 bats at that price usually they're £200 + unless I'm mistaken.
Yes, you could be right Antdad, - the Makita might be decent enough, although as you know, there are cheap DIY & more professional versions from most manufacturers which all tend to look like same quality & usually with deliberately confusingly model numbers. I decided to avoid the Makita with one battery partly because I think two batteries are essential for times when the drill power dies.
Maybe cheaper versions of Dewalt are also worth a look at. Guess it is what feels good in the hand.
I have some 22volt Hilti stuff now, which are so powerful. I won't ever go with underpowered cheap drills anymore.
I didn't consider the white makita could be a cheaper DIY version, could be or perhaps it has more appeal to female DIY'ers? Dunno never handled one, just saw it advertised.
Perhaps we should ask the OP what the hell he's going to be using it for...LOL.
For £90 you'll be getting plastic gears in all the branded stuff. The macalister stuff in b and q is actually hard wearing and cheap enough to be disposable. Mechanic I know purchased their impact wrench with that notion and still has it 3 years on
At that price you will get a medioca drill but if you could go that wee bit further then the quality rises. Makita have a couple good drills on offer but for 90 quid the batteries supplied although 18v there less oomph at just 1.3 ah as I see there onto 4ah
Hitachi DV18DGL/JC 18V 1.5Ah Li-Ion Cordless Combi Drill | Cordless Combi Drills | NoLinkingToThis
DeWalt DC100KA-GB 18V 1.3Ah Ni-Cd Cordless Combi Drill | Cordless Combi Drills | NoLinkingToThis
add £20 and get one of these. hitachi has metal gears and 3 year warranty, dewalt is a workhorse(check out the reviews) and is what many apprentices and semi trades buy.
thanks all for the advice, i think ill get thehitachi-dv18ds 5ah 18v as its in my price range and it wont be used for heavy work just for clipping out pipework and hanging rads and basins
Thease are carp DIY drills,go for the bhp 458 series,amazon were flogging them with 3 amp batteries and a charger for under £200,world apart in power and durabilty
They are great drills. More than you will need.
Wouldn't touch those 1.3 a/h makitas , got one myself and absolutely zero oomph batts forever on charge
ordered a hitachi combi drill with 2 x 1.5ah li ion batterys and a titan sds drill cause it was on offer,thanks for all your advice
zack
Reply to good 18v cordless? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all i need some help and advice i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts and trying to create a template. I've noticed when i drill holes into the tiles sometimes they would crack. i don't use any pressure or drill too fast...
1K
Hi all, I have a combi boiler for hot water and heating but have 2 showers in the house. Obviously low water pressure if both showers are used at same time. I'm wondering if I could install a water tank to gravity feed one of the showers, with new electrric shower and if so how to stop the water...
Hi All, My mum had a Worcester green Star 4000 fitted on one of those eco grants. A external filter wasn't fitted. Should this have been fitted or is it deemed a good to have item so not under any regulations? Thanks
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
Hi everyone, Just a query about what size in KW gas combi boiler do I need for a top floor flat (3rd floor). I have a Vokera Easi heat plus (20kW) gas combi boiler and it does the job, the radiators never go as hot as the should for example there are ten dots on the heat dial but the radiators...
1K
