Discuss Glowworm hideaway 80 bf in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
Before i invest in a new gas valve "thoughts please".
Pilot light ok, all controls calling for heat burner wont ignite????
Boiler is a floor standing glowworm hideaway 80.
Thanks in advance.
I think this this won't get an answer unless you put it in the area reserved for Gas Safe installers, which you can't do until you've registered with the forum as a Gas Safe registered gas installer.
Are you gas safe registered?
Are you getting voltage at the gas valve when calling ?
@Lou any chance you could grant the op into the gsr forum?
@Last Plumber will leave this here for now until the op has he badge
If you can help, help away will make it all safe / move it later on
Hi the op needs ten posts before access can be granted.
Right will move this out of the open forum
Reply to Glowworm hideaway 80 bf in the Plumbing Jobs | The Job-board area at PlumbersForums.net
