Discuss Glow worm boiler engineer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
ma701ss
Anyone recommend an engineer experienced with Glow Worm boilers in the Bromley, Kent area? Boiler is a British Gas 330 (G.C. No. 41-047-75). Are the Glow Worm directly employed engineers any good and experienced with the older boilers (installed 2006)?
Thank you for the opportunity.
If this job interests you please PM the op direct.
Reply to Glow worm boiler engineer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Got back from a week visiting family over Xmas and our boiler has now started making banging and grinding noises. It’s a British Gas 330 which is a Glow Worm boiler.
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again before firing and running. Occasionally shows the flame is lit on display but flow temp doesn’t go much past 26. Then if you turn off and try again...
Can anyone tell me of a boiler equivalent to a Glow worm micron 30ff. I am not sure what one I should get?
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
The flue for a glow worm micron 30ff is apparently obsolete but there must be other flues that would fit it surely, it's just a standard 100mm horizontal flue right? I mean when a bg gas engineer tells you that you'll have to change the whole boiler as well because you can apparently no longer...
