Discuss Geberit 290 Universal Flush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
First post I'm afraid - can I ask all of you for some help? We have just had a new loo installed with the above geberit flush and inlet valve. The flush initially works fine but after a while water still seeps into the cistern and eventually starts to run through the overflow. There's no leak out of the cistern - if I turn the water off via the isolation valve then overflow stops. I have also considered the fact that the water pressure may be too high but turning the flow down doesn't make any difference either. I have spoken to Geberit who thought there might be dirt in the diaphragm inside the inlet valve which was allowing water to seep in, but it was brand new and, having taken it apart I am sure there was nothing there. Anyway, out of desperation I have bought a new inlet vale and fitted this with high hopes only to find - same problem. Could it be that it's just a rubbish system? Any suggestions to diagnose the problem would be very welcome - thanks in advance.
Good quality stuff there.
It will be dirt, or theflush valve is not seated correctly.
Why are you doing it instead of the installer?
I'm fairly sure it isn't dirt - I changed the valve so it would be unlikely for two brand new valves to have a spec of dirt inside. I'm trying to fix it myself to try and sort it before Christmas.
Have you got high water pressure ? turning service valve down wont make any difference, cant remember if these valves come with a restrictor that fits inside the valve
There is a pump fitted that would increase the water pressure - I don't know what the pressure actually is. I did think that high water pressure might explain this - I'll investigate further.
Reply to Geberit 290 Universal Flush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, We have a Geberit UP720 frame. The frame says depth 8cm. (There's also the UP320 frame, which I guess is 12cm.) We are looking at Geberit flush plates, e.g., Sigma10. Sometimes we read that UP720 is compatible with Sigma flushplats. However, sometimes flush plats are also advertised...
A few years ago I installed a wall hung toilet pan in my last house which did not flush well when disposing of waste solids. The water would rise up to the rim then dissipate and usually required further flushing to complete the disposal. I don't recall the brand but the wall mounting frame was...
I have a Geberit concealed cistern . This has a dual pneumatic flush, and has worked without any problems for a few years now. The short flush continues to work normally but the longer (6 litre) flush no longer flushes fully which results in solid waste not being flushed. I have checked the...
1K
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the night so I fitted a simple pull cord swith to turn it off at night About a month ago I recently had a blockage so pulled it apart and cleaned everything...
Hello, I have to replace the flush valve and/or the washer but unfortunately it's inside the vanity unit. The only way is removing the toilet. I turned the screw on the cistern pipe to stop the water. I removed all the silicon around the toilet, now I can easily lift up the Front panel but...
