Discuss Gas oil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
P J F PLUMBING
Hi guys I'm really stuck. I priced for a job to replace a boiler running on gas oil. Red diesel I am replacing it with a SE warmflow floor standing combi to run on gas oil red diesel It's in a factory so it's excempt from being HE . Can I come off the back of the boiler and discharge at low level ??? Also do I need to drop a nozzle size or jiggle the pump pressure I'm really confused I've fitted HE boilers on 28 second but this is the hardest one I've tried to do many thanks in advance Pete
Yes, just make sure you've a cage around the terminal to prevent people burning themselves
I've put the SE manual in my drop box, I'll pm the link to you in a miute, look at page 28, all there for you buddy!
If burning gas oil the flue must terminate at least 6ft from ground level.
Ok really confused now the really old one that's there is vertical flue the new one I'm hoping to put though the wall and discharge low level with a cadge its going to discharge into the factory yard by the docks help now please very lost with all this
No confusion you cant do it.
[DLMURL]http://warmflow.tpsrv.co.uk//media/1332429868SEmanual.pdf[/DLMURL]
Page 5 says you cannot use the low level flue supplied and the flue gases must terminate at least 2m above ground level.
Well I'm really thankfully to all you guys for your help I would have really ffffed this up if I'm honest I'm going to do some more research scratch my head ect many thanks pete
tooth fairy may be a fake but the flue fairy is for real, thanks for that kimbo, one to note for farmer installed oilys
Hi guys can I use I l 5 inch or do I have to use S I L 5 inch. being told so many diffent things from my suppliers warm flow are no help. They say class one or two Is there gas and oil flue ????? Standard efficentcy boiler running on red diesel this is the most complex job I've ever done help please
It's in a factory about 9 meters I'm really stuck had a huge price for S IL HELP
You could if the phone wasn't in the van. Left it in there tonight and it's absolutely chucking (had to be careful there, thought we were in the arms :) ) it down so it can stay put for a while.
I've always used a couple of lengths of stove enamel to get it up high enough and then out through the wall.
Don't know if you could use 1 length of stove enamel and then onto a stainless flexi flue and up. Then box in the stainless with some concrete board using metal studwork? Never had to get something that high as 99% of mine is domestic.
That's so helpfull thanks so much mate really am great full
Yea ill sort later it was so much work I had to drop a nozzle size fiddle with the pump 97 quid a meter for flue stressed
Well got a call today boilers not working. Ok what's the pressure on. 0 bar ok top it up and it will work. An hour later 0 bar So I said you must have a leak on a rad no we haven't ok I said is my boiler or any of my pipes leaking no so I said I've connected onto your system as stated. We're not paying till its fixed how do I sort this outs??? Not happy
Did you have a disclaimer in your paperwork regarding the existing system?
Reply to Gas oil in the Plumbing Jobs | The Job-board area at PlumbersForums.net
