Discuss FOR SALE, mapress copper & carbon fittings, lever valves, copper to irons in the Plumbing Jobs | The Job-board area at PlumbersForums.net
s.hemming
please PM your offer for the lot & contact details if interested
based in london delivery/collection
MAPRESS COPPER
14 X 54mm MALE IRON
11 X 35mm MALE IRON
22 X 28mm FEMALE IRON
2 X 28mm MALE IRON
24 X 15mm FEMALE IRON
4 X 15mm MALE IRON
15 X 22mm MALE IRON
2 X 42mm MALE IRON
COPPER MAPRESS
5 X 28mm STRAIGHT COUPLING
4 X 28mm SLIP COUPLING
3 X 28mm 45 DEGREE BEND
1 X 28mm 90 DEGREE BEND
3 X 28X22X22 TEE
2 X 35mm SLIP COUPLING
2 X 35mm COUPLING
1 X 35mm EQUAL TEE
1 X 35X35X22 TEE
9 X 15mm EQUAL TEE
1 X 15mm 45 DEGREE BEND
1 X 15mm COUPLING
2 X 54mm 45 DEGREE BEND
1 X 54mm 90 DEGREE BEND
1 X 22mm EQUAL TEE
2 X 42mm 45 DEGREE BEND
1 X 54mm EQUAL TEE
3 X 42/28mm REDUCER
1 X 42/35mm REDUCER
2 X 54/28mm REDUCER
1 X 42/28mm REDUCER
3 X 28/22mm REDUCER
1 X 28/15mm REDUCER
2 X 28mm/28mm/1/2" FEMALE IRON TEE
1 X 42mm 90 DEGREE BEND
MAPRESS CARBON STEEL FITTINGS
1 X ( 67.7MM X 35MM) REDUCER
5 X 89MM COUPLING
2 X 89MM 90 DEGREE BEND
1 X 89MM M/F 90 DEGREE BEND
1 X 89MM 45 DEGREE BEND
1X 89MM/89MM/54MM TEE
1X 89MM X 89MM X 3/4 TEE
17 X 67MM 90 DEGREE BEND
2 X 67MM 90 DEGREE M&F BEND
2 X 67MM COUPLING
1 X 67MM 45.DEGREE BEND
8 X 54MM 90 DEGREE BEND
1 X 54MM EQUAL TEE
2 X 54MM/54MM/22MM TEE
1 X 54MM/54MM/28MM TEE
2 X 54MM EQUAL TEE
1 X 67MM/54MM/67MM TEE
3 X 67MM/54MM REDUCER
1 X 54MM X 2"3/8 UNION
1 X 42MM 1"3/4 UNION
4 X 42MM MALE IRON
4 X 42MM 90 DEGREE BEND
7 X 42MM COUPLING
3 X 54MM MALE IRON
3 X 54MM/35MM REDUCER
1 X 42MM/42MM/22MM TEE
2 X 42MM/42MM/15MM TEE
1 X 42MM 45.DEGREE BEND
2 X 35MM UNION
1 X 75MM/67MM REDUCER
2 X 35MM/35MM.1/2" TEE
GAS GEBERIT MAPRESS CARBON STEEL FITTINGS
9 x 89MM COUPLING
1 X 89MM/75MM REDUCER
2 X 89MM M/F 45 DEGREE BEND
2 X 89MM EQUAL TEE
2 X 67MM/54MM REDUCER
1 X 54MM MALE IRON
1 X 108MM 90 DEGREE BEND
3 X 108MM COUPLING
2 X 108MM/67MM/108MM TEE
33 X 3/4" FEMALE LEVER
15 X 1/2" FEMALE LEVER
1 X 2" STEEL FEMALE LEVER
1 X 2" FEMALE LEVER
2 X 1"1/2 FEMALE LEVER
15 X 1"1/4 FEMALE LEVER
33 X 28MM FEMALE LEVER
4 X 1" FEMALE LEVER
2" LEVER COMPRESSION
1 X 2" DOUBLE REGS VALVE (DRV)
6 X 28MM DOUBLE REGS VALVE (DRV)
1 X 1" STRAINER
28MM FEMALE GATE VALVE
12 X 1" caleffi pressure reducing valve
20 X 15MM LONG NECK DRAIN COCK
6 X 7 BAR GAUGE
20 X 28MM MALE IRON
5 X 28MM FEMALE IRON
KEMPLAR
AAV
1 X 54MM MALE IRON
35MM FEMALE IRON
54MM FEMALE SOLDERED
is it xpress (yourkshire) or gerberit mapress?, as most people call x press mapress
Geberit mapress copper crimped fittings, copper to irons, lever valves & Carbon steel X-press fittings
payment wise paypal or what?
MAPRESS COPPER
14 X 54mm MALE IRON
11 X 35mm MALE IRON
2 X 28mm MALE IRON
4 X 15mm MALE IRON
15 X 22mm MALE IRON
2 X 42mm MALE IRON
COPPER MAPRESS
3 X 28X22X22 TEE
2 X 35mm COUPLING
1 X 35mm EQUAL TEE
1 X 35X35X22 TEE
9 X 15mm EQUAL TEE
1 X 15mm COUPLING
1 X 22mm EQUAL TEE
1 X 54mm EQUAL TEE
3 X 42/28mm REDUCER
1 X 42/35mm REDUCER
2 X 54/28mm REDUCER
1 X 42/28mm REDUCER
3 X 28/22mm REDUCER
1 X 28/15mm REDUCER
5 X 89MM COUPLING
2 X 67MM COUPLING
1 X 54MM EQUAL TEE
2 X 54MM EQUAL TEE
4 X 42MM MALE IRON
7 X 42MM COUPLING
3 X 54MM MALE IRON
2 X 35MM UNION
9 x 89MM COUPLING
2 X 89MM EQUAL TEE
1 X 54MM MALE IRON
3 X 108MM COUPLING
1 X 2" FEMALE LEVER
4 X 1" FEMALE LEVER
1 X 1" STRAINER
6 X 7 BAR GAUGE
20 X 28MM MALE IRON
KEMPLAR
AAV
1 X 54MM MALE IRON
35MM FEMALE IRON
Still Available
Could be interested in the copper (we use xpress, though our tool will do both)
Would you split copper / carbon steel
Reply to FOR SALE, mapress copper & carbon fittings, lever valves, copper to irons in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with elbows), the last cm before the open end is pretty much straight, but as a result of the bend it is not perfectly round. I mean it is pretty much...
I have a Victoria Plumbing concealed valve with 3/4" and 1/2" female inlets/outlets. I need to connect male iron 90 degree elbows (with compression fittings to the pipework). Should I use straight or parallel threads into the valve? I am thinking that I can use straight if I use Loctite 55 cord...
2K
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm. This question is for my own house setup. We are really fortunate to have a large house, about 5,000sqft in total over 3 floors. It was built around...
1K
H
HRP123
H
I wonder if anyone can help, I've tried several plumbers merchants to no avail. I have removed an old stopcock, (which seized long ago, with a newer stopcock just above) as it had been leaking from several places, mainly at the bottom where it joined the 3/4" threaded female end on rising main...
2K
