Discuss Flow rates in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ISM
Do baxi limit the flow rate on their duo tec boilers? Namely the 40kw model. Or is just 16.4 l/m at 35 degree temp rise.
You can have more but it wont hit the 35 degree rise
Depends on the incoming flow.
For example glowworm limit their boilers with a flow limiter, do baxi do the same?
Not that im aware of. As im sure ive seen morr flow with a 30 degree rise somewhere.
Baxi tech support are good and fast - maybe worth a quick call ?
It will, or should do as it says.
Like Newcastle said, If you pass more through then you get less temp rise.
Is that what you meant ?
why are you asking
Reply to Flow rates in the Plumbing Jobs | The Job-board area at PlumbersForums.net
