Discuss Flow and return in airing cupboard. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Guys,
After a long lay-off I am looking at getting back into the gas industry. I have tried to attach a drawn pic, but was unable to due to a repeated error.
My question is, if a conventional boiler is fitted within an airing cupboard (above the DHW cylinder - vertical flue) and the F/R pipes had a topside exit, I can simply connect the vent and cold feed to the flow above the boiler before dropping down to the pump, to then feed by-pass valve and so on...?
Also, just to confirm, would a manual air pip also be best placed on the return pipe out of the boiler, as well?
Thanks in advance.
Best to check head height and configuration in manufacturers instructions before committing. Are you registered to do this work?
Thanks for the reply, Vee.
I actually completed a full apprenticeship in plumbing and heating and passed my ACS, but that was some ten years ago. I am planning to re-enter the field in a few months, and was just recapping on a few things...
I am not planning to undertake any work. This is more for theory. Basically, an attempt to jog my memory...
I remember completing a few of these back in the day (Baxi solos conventional - some sealed - some open vented), but for the life of me I forgot how I configured the exiting pipework out of the boiler...
Guys,
Thanks in advance.
Are thinking of going straight down into the pump, so it's pumping downwards? That's possible but I believe it's not ideal. Perhaps others will comment. Alternatively you could add a U-bend before the pump.
By manual air pip(e) do you mean a manual air release point? That would be useful to aid venting on initial fill and commissioning. You wouldn't want an open vent pipe there.
Thanks for the reply. And yes, going straight down to the pump. I have managed to attach a drawing of what I am trying to write...
The above diagram assumes that the boiler is sited above the HW cylinder in the airing cupboard... And yes, I meant manual air release point :)
Just for interest, is pip a term for an air release point? I thought you'd misspelled pipe?
Sorry for the confusion. I was taught the correct terminology in college, but the engineer I shadowed during my apprenticeship always termed it 'air pip', or sometimes even just 'pip'.
You need to check that the static head for the boiler and the pump meets the manufacturer's requirements. That's the drop from F/E tank water level to the boiler and pump inlets. If it's not sufficient the F/E tank may need raising (which could have a knock-on effect on the relative positions of F/E tank and cold water tank!).
Reply to Flow and return in airing cupboard. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello folks I've moved into a property last month and started to note things that may need looking at. Some of the radiators on the ground floor aren't getting very hot, I've had a few passes of balancing to no avail, In light of the above, I took a look down in the subfloor yesterday to take...
Please can anyone let me know if the NTC thermostats are on the correct way around?? I did have problems with the return pipe heating up before the flow so I'm thinking the last plumber may have swapped them around somehow. Havin now reconfigure the central heating i've plumbed in all the...
Seems strange and I may be reading the MI wrong but i dont understand how the return pipe seems to be hotter than the flow. I have a Vailant EcoTec 438 conventional condensing boiler. Here's a photo of the install. You can see the plumber put a Magnaclean on what i thought is the return flow...
1K
The pipework around the hot water tank in the airing cupboard has developed several leaks after a chemical flush. It's an open vented system. Any ideas on controlling or fixing the leak? Should I turn off the red valve (pic 1) that has a leak next to it and rundown the hot water? Pic 2 a...
I'm in a bit of a bind with a current CH install where I need to install a filter prior to a flush but no where to install My issue is the return on the combi (ideal 35) runs directly behind the boiler then up through the ceiling so I have no clearance to even attempt to snake it out to fit a...
