Discuss Fitting a surface mounted shower mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
I have a Crosswater surface mounted shower mixer to fit but it doesnt come with any
wall brackets to give a connection to the supply. Comes with an S bend threaded at each end.
I have copper supply pipes coming through the
tiles.
I have tried my local plumbers merchant but they dont have anything suitable.
I think what I need is a brass wall bracket which I can connect to the copper supply pipes.
What is best to use and where could I source?
hi mark you need something like this
from toolstation item no.27320
- Status
Reply to Fitting a surface mounted shower mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, hope all is well!
I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is very slightly out of shape. It leaked but I added some PFTE tape over the olive and it seems to of done the job. However…
I’m tiling the wall and...
Hi All.
My Aqualisa Aquavalve enclosed mixer shower valve leaked and gave way and I am looking to replace. I am looking for recommendations what model would I replace it with and how would I replace it if I changed the model! I would like to change the type of model to a lever one.
I have...
hi all
i hope you are all well
i'm planning to install my shower mixer on Saturday. today i was doing a dry fit and i wanted to show you some photos and questions. i'm using fast fixing brackets. i was wondering what length do i cut the pipe to? also my shower bar mixer has these cone shaped...
hello all, happy new year!
i hope i have posted this in the right section
i have a shower bar mixer. the shower runs luke warm. a quick google search showed some ideas on how to adjust it. i tried adjusting it and it didn't change the temp. when i adjusted it the other way to test the cold...
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge of the cold water pipe and explained that there were two options:
1. Get into the wall with a jackhammer to fix the problem; or
2. Install one of...
