Discuss First time poster: Swaging vs crimping - same thing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eahoop
Hi all,
Am involved in heated debate, so heated that I have registered here just to get my answer once and for all!
I know the term swaging is usually used to refer to the punch swage you hammer into the end of a pipe section to increase the end diameter.
But I'm seeing some instances of pipes which I would call crimped being referred to as 'swaged', and have found tools that I would previously have called crimping tools being sold as swaging tools. I can't post links because as a new member it won't let me!
My argument is that swaging is likely an umbrella term for all processes involving the use of a tool to alter the diameter of an end section of pipe; therefore a crimping tool is also a swaging tool.
My friend and colleague is convinced that the two are entirely separate and should not be referred to in the same instance.
This is only made more complicated by the existence of the sleeve-to-wire rope version of swaging, which is definitely ALSO called crimping.
What are your thoughts on this? Would you say only the traditional punch and die swages that we have traditionally called by the term count, or is crimping - being that it reduces the diameter of the end of a pipe - also a form of swaging?
Bonus question: What about flaring?
Let's settle this once and for all.
Thanks!
- E
Swage is not same as crimp. Unless u swage the pipe then crimp it around pipe of same dia?
But if you have swaged it, then its not the same diameter :)
Shame the worlds only problem isnt the mass debate on swage and/or crimp :)
True, Simon. But there's nothing like a good mass debate now and again to relieve tension...
OP - I would use the terms swaging and flaring interchangeably in this context. Crimping is different. But your point about swaging sleeves on to cables does throw a spanner into the works!
Both made with a tool you hammer in the end of the pipe.
Sadly anything that involves stretching the pipe is loosing popularity ,
thinning = weakening
Insurers don't like that !
Reply to First time poster: Swaging vs crimping - same thing? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing with it as a matter of course. If I'm wrong can someone let me know and I'll shift it to a better place.] I have a condensing boiler installation...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
Hi, I'm looking for some advice on how to proceed with my current situation. We bought a new build and after getting my boiler and unvented cylinder serviced my plumber raised the fact that he estimates the D2 discharge pipe to have a resistance flow length on 12m and as it's 22mm copper pipe...
1K
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I think was very... ambiguous... advice. 12yo boiler with the following readings on the analyser printout: O2% = 4.1 CO ppm = 192 CO2% = 9.5 Ratio =...
Hi all, Excuse the length but this seems like a complicated fix. I lived in a 1930s block of flats. Brick building with concrete slab floors. The waste stack is internal and bricked into corner of the bathroom. I noticed paint peeling and brown staining recently at the bottom near the...
2K
