Discuss Firebird oil boiler non starter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wolbut
Hi - i have a Firebird combi 90 oil boiler - working fine until last week when the flow switch split - turned off the mains supply to it and isolated the water - fitted a new switch 5 days later -turned water and power back on & tried to restart it - the blower/fan is running but the burner does not fire - it does not even try to fire - any ideas ?
Has it got a rdb burner that is the one with the red plastic cover surround. If it has it is a classic symptom of a faulty photocell. To check turn off boiler, open top of control box and remove brown and blue wire of photocell (just pulls off) start boiler again, if it fires and then goes to lockout then that confirms a faulty photocell.
thanks Kimbo - its a Riello burner - i will try pulling the wires to the cell in the morning ( its an outside boiler and its dark)
Thanks Kimbo but the photocell is soldered in place on a PCB so could not disconnect it and do the test
Top man - yes it slides off -- unfortunately it still would not attempt to start - thanks anyway
Hi Kimbo - fitted a new control box and photocell - still no joy !
Hi Kimbo - not a lot happens ! -- when i switch the elecs back on the blower runs and thats it ! doesnt try to fire - i made sure the stat is calling for heating - but as its been off it should start anyway to build heat for the hot water circuit - and i have made sure its getting a supply of oil - at least its getting to the pump - maybe its the coil on the solenoid ?
my mistake did not read the original post correctly!
If the Ignition Probes had somehow been knocked out of alignment, (not that I see how they could have been), It would still lock out though wouldnt it :-/
Thanks guys - followed the link - only have continuity on the blue-black wires so i will try a new coil -- getting 55v on the white wire; 2volts out of limits but it may be my meter (not been calibrated for a looong time)
will let you know the results
Hi Guys - fitted a new coil but no better - checked continuity of the new one against the old one - both only have continuity on one pair of wires - i reasoned that the new coil being new in OEM wrapper was most likely to be ok - started again from scratch : cleaned the nozzle on the injector(it was clean) very slight adjustment on the electrodes - refitted the new control box and she started to fire up - after a couple of lockouts all is well - refitted the old box and it did not work !
So with your help i have fixed it - must have been a combination of faulty control box and electrodes out of spec - thanks again
Reply to Firebird oil boiler non starter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My firebird oil boiler hw supply is luke warm, but does heat up slightly when run if the ch is on at the same time. Is this a faulty diverter valve? If so could I replace this myself as I've heard they're expensive to fix. Tia
2K
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts needed to operate it are now new. The symptoms indicated a broken/seized burner motor or oil pump. I wrongly assumed the motor so I ordered a new one only...
Hi there. I have Grant oil fired boiler which when cold, takes multiple times to fire up. It will run for say 20 or 30 seconds with hot exhaust gases then it stops. The fan is still going then it starts off again and stops again. After 4 or 5 goes it runs fine. When the boiler gets up to...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
