T
Tarquin
Woken this morning to the screams of my missus as the recently fitted downstairs bathroom filled with water that gushed from behind the unit holding the sink!
Having recently fitted a proper pressure reducing valve under the bath to serve the shower, returning the isolation valve to full on has obviously exposed a weakness up the line. I'm hoping that it's just a 90 degree HEP angle that wasn't properly tightened and that without too much trouble i'll be able to get a small fingered family member to sort.
Had this happened when we were out the damage would have been astronomic so I need to ensure the repair is done with confidence that it won't fail again.
Apart from being poorly tightened are there other reasons that I should consider for the joints failure?
