Discuss Facing Boiler problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a combi boiler and from past few days it is making heavy noise when I open the tab and the water is still very cold. I have waited for 20 minutes but the temperature remains same. I have restarted it many times but it doesn't work. I spoke to some of my friends who are engaged with plumbing industry and they tell me that its the problem of the radiator and many more things which I didn't remember. They suggest me to concern with experts. Then I contacted my local gas safe engy and they confirmed that it is because of the failure in the board. They repaired it and after 3 days I face the same problem. The only thing that I can do is to take suggestions from you. So guys please help me to figure out this problem.
When they repaired it , did it work for 3 days and then stop ?
What make is the boiler, and have you any idea of its age ?
Good Morning Jane, unfortunately there is not a lot we can help you with at the moment. We will need more information, What is the make and model of your boiler? Does the heating work? what is the boiler doing when you turn on a hot tap? With a bit more information we may be able to make a few suggestions but ultimately it is best that you employ the services of a local GSR engineer to have a look at it for you.
I have a combi boiler and from past few days it is making heavy noise when I open the tab and the water is still very cold. I have waited for 20 minutes but the temperature remains same. I have restarted it many times but it doesn't work. I spoke to some of my friends who are engaged with plumbing industry and they tell me that its the problem of the radiator and many more things which I didn't remember. They suggest me to concern with experts. Then I contact nearby boiler engineers and they confirmed that it is because of the failure in the board. They repaired it and after 3 days I face the same problem. The only thing that I can do is to take suggestions from you. So guys please help me to figure out this problem.
You need a Heating Engineer to look at it.
If it's Gas they must be registered. Try the Gas safe website, it will have the Engineers nearest to you.
It doesn't sound like a PCB fault to me, going off what you have said.
Yeah! It worked for 3 days and then the same problem occurs.
I have installed that boiler in the start of winter.
It must be in the warranty period still?
Phone the manufacturers and they will send an Engineer. If it is a fault with the Boiler it will be covered.
What boiler is it also what's the fault code showing up ?
Also you get around last post was in Sweden now your in Bosnia o_O
Reply to Facing Boiler problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up a flashing 79 code. Try restarting the boiler straight away but I have to wait 10 minutes for it to cool down before it works. I reset the boiler...
  • Locked
Hello, I have a ferroli falcon 2 boiler (yes it is pretty old). A few days ago the hot water started going hot and cold when running. Monitoring the boiler, the demand light works fine. When the water gets up to temperature every 10 seconds or so, the boiler stops for a fraction of a second...
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some times the flame failure light comes on but it ignites again after a few seconds. The plumber has changed a couple of sensors on the boiler and checked...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the 1st time this season I found a problem with the boiler not running on one of the zones. If I turn on the heat to zone 1 I hear the system...
