Discuss expansion vessel pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GQuigley67
what do you guys use to re-pressurise EV ? would like a decent valve with gauge so i can attach a normal bike pump to.
to check the presure ive got a gauge from halfords and to top up i use the boys bike pump.......
Foot pump and I have a ÂŁ2.99 pressure gauge to push on to the fitting. Also have a lorry tyre extension tube (from tyre garage) if the foot pump won't fit properly.
you all want to get your selves the baxi adapter for the duotecs i will post a photo up tomorrow if i remember,it makes going on to ev,s easy
I use one of those battery pack jump starter things with a compressor on and check it with a pen type pressure gauge. Bought the battery pack for about ÂŁ25 from some poundstreacher type shop and the gauge from a car parts shop for about a fiver. Pumped up in under a minute.
Something like this
[DLMURL="http://www.maplin.co.uk/portable-jump-starter-and-air-compressor-49038?c=froogle&u=49038&t=module"]Portable Jump Starter and Air Compressor Free Delivery : InCar Battery Chargers and Compressors : Maplin[/DLMURL]
Something like this
looks good tamz,but these days I treat pumping up expansion vessels with foot pumps part of my much needed exersise !! if fact sometimes if I have had a quite gas safety day ,I let it back down and pump it up again a few times :p:)
[DLMURL="http://www.reginproducts.co.uk/flowandpressure/REGK30"]REGK30 - Pressure Vessel Pump | Regin[/DLMURL]
Is it like this?
[DLMURL="http://www.reginproducts.co.uk/flowandpressure/REGK29"]REGK29 - Pressurisation Pump Angled Adaptor | Regin[/DLMURL]
The tyre pump in the back of my van does the job fine. I keep a stock of schrader valve stems too and replace if there is a problem
I got a regin stirrup pump I managed to blag. lovely long hose on it!
same one in soccer sport ÂŁ7 , bought mine a few week back
i got this one
long hose perfect for me.....
I used to use a machine mart air brush pump up until a few weeks ago, had the original pump for about 4 years. It gave up the ghost and died, i found it excellent for topping up large comercail vessells.
I have just replaced it wit a slightly larger shhhhh unit, again from machine mart, expensive but very quiet and fast.
Reply to expansion vessel pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
