Discuss Excuse me for being dumb as a post in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
But never fitted one of these fellas before.
Do you just cut them down to your required size?
Croydex L-Shaped Shower Curtain Rail & Support Chrome Chrome Effect 2000mm
Yes but measure 3 times cut once :D
You're excused - for being as dumb as a post!
To answer your question - I assume so
Is this a new competition to find the Dumb arsed question of the month? :D
Reply to Excuse me for being dumb as a post in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is very slightly out of shape. It leaked but I added some PFTE tape over the olive and it seems to of done the job. However… I’m tiling the wall and...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar. Connect to this is a 1.5 bar Ora Salamander pump for a positive head, this was connected by a plumber of course and we’ve had it all rigged up...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat up but they are all connected via what I assume is Hep2O nothing is labled on the pipes that route behind the rad just on the flap behind the rad...
Hi everyone, I'm looking for some advice please. My system has 5 Drayton Wiser TRVs. There are 8 rads over 3 storeys and a 170l unvented cylinder. One of the attic rads is in the same zone as the cylinder so just has a "dumb" TRV on it. The two bathroom rads also remain without TRVs and I...
2K
Hi all, can someone get to the bottom of this before I call a plumber, en suite shower started leaking from the mixer bar so took the shower off and capped it off for the time being, fast forward 3 months the same thing in the main bathroom, that one is leaking from the mixer bar, (no issues...
