Discuss electric heater element and the thread size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
I've got a question about the electric heater element and the thread size..
Thread Diameter : 32mm / 0.11";Color
I need to buy a nut for this but not sure what I need.. BSP, NPT, NPS, Metric?
32mm is pretty much 1.25 or 1 and a 1/4 inch
http://www.amazon.co.uk/gp/product/B...ilpage_o02_s00
Reply to electric heater element and the thread size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking to see what iron pipe part can fit a 10mm ball joint? In this pic there is a part that connects the ball joint (or whatever they are called) to the 1/2 inch pipe. I am looking to connect to a 3/4 inch pipe. Are there any threads that do this? Thanks I have been told that in North...
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from. Why I think its I've used calipers on the threads and counted them, and the male end sticking out of the vessel is BSPT 3/4 with 14 threads per inch...
I am trying to source adaptors/reducers for the below taps for my renocation We have the tap ware currently but Union adaptors are needed to fit the Australian copper pipe sizes of ½ and ¾ Can anyone suggest where to get these? Thank you in advance Antony Tap 1 From the USA - has a 3/8 pt...
Deleted member 120897
The inside brass threads in my Moen rough in two handle Roman tub valve (Moen | Bathroom & Kitchen Faucets, Shower Heads, Accessories & More - https://www.moen.com/products/M-Pact/M-Pact-Two-Handle-Roman-Tub-Valve-10-Center-1-2-CC-Connection/4796) were cross threaded with the nylon cartridge...
T
Hi, I want to fit an immersion heating element to my hot water tank (water is currently heated by gas). I'd like to buy it before I start draining water from the tank. The plug in the tank has a 1 1/4" nut on a pate approx 3" in diameter, does anybody know what size thread the tank will have...
2K
