Discuss Elbow at wrong angle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mr_T
Hi and thank you for reading. I am installing a shower valve which requires a 3/4 male threaded fitting. I am using a make 3/4 thread that goes into the valve and the other end is 22mm compression fitting. The connection is elbowed. The issue I am having is when the elbow is screwed all the way into shower valve I end up with the compression end at the wrong angle. I would have to back it off a quarter of a turn for it to line up with the pipework. Will ptf tape be sufficient to stop any leaks if the elbow is not tightened all the way home?
Give it a few extra wraps of ptfe and wind up til it gets tight and then set to your angle. Don't turn back though
Reply to Elbow at wrong angle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
