Discuss ecoTEC plus 824 problem. No hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pdcleeds
I have a problem with an EcoTec plus 824. When calling for the hot water it fires up and doesn't give hot water but heats the rads up. fault code suggested the diverter valve, looking the diverter valve is all crusted up so I changed this. But still getting the same thing cold water when calling for hot and rads warming when they shouldn't. Display shows the tap when calling but just not having it....
Can you hear/see the valve head moving in and out? The plate heat exchanger can cause a similar issue if it's badly blocked.
Have you checked that both filling loop levers are closed under the boiler. The boiler is designed not to give you hot water if one of the valves is left open.
Reply to ecoTEC plus 824 problem. No hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads in the house and a room with UFH. The LLH was introduced as I was finding (before the LLH was fitted) that my old boiler (Vaillant heat-only boiler)...
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs mostly at night. I'm sharing video showing the problem: So far we changed: 1. Expansion vessel 2. Pump 3. Water pressure gauge - analogue sensor...
Vaillant Ecotec Plus 832 boiler is 13 years old, 4 of which since we've been living there, started to play up in last couple of months. An engineer with very good reviews came round and says it will cost 700+VAT for 'replacement expansion vessel, pressure relief valve and diverter valve on...
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the outputs goes to a 2 port diverter prior to the Megaflo (I believe this is some safety feature). I have run into an intermittent problem where some...
