Discuss Ecocent vented cylinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DanPlumb
Hi all,
I have been to look at a problem today where this type of cylinder has been fitted ( ecocent vented ) it is linked up to a ASHP. the problem is the showers are constantly airlocking. With the hot water system being vented it has three shower booster pumps fitted to boost hot/cold water pressure to shower three different shower, there is only one hot water outlet on cylinder which runs upover then horizonatally to a tee piece, the top outlet on tee is the vent going over the storage tank above and the other going down to feed three shower pumps and other domestic hot water outlet within house.
Obviously with normal vented cylinders you usually fit an essex/warrix to the cylinder for a shower pump, i am thinking when the showers are ran the air is been sucked from the expansion pipe. Anybody fit these systems who may be able to help please?
Many Thanks.
You are correct, air being sucked in. It has nothing to do with it being an ecocent, just bad plumbing design. Re-configure the pipe work.
Hi DanPlumb .... may I first say I haven't got a clue what you're talking about regards cylinder! However the principals of open vented systems haven't changed that much over the 30-odd years I've been about! You got to supply the requirements otherwise something will give!
How long has the system been installed? New means installation issues, old means component or circulation issues! Have the showers been added subsequently? Things to consider eh ?
Thanks for the quick reply! Yes i realise its nothing to do with the ecocent itself just wondered if there was any fitting you can buy thats compatible with the cylinder o prevent air been sucked in like you get with normal vented cylinders ( essex flange etc) just i cant see how you can possibly add another tapping to the cylinder with in been in an insulated casing. The cylinder only has the one outlet. Sorry if i seem confused ha, just cant see it been as simple as a normal vented cylinder.
The Ecocent can also be installed as an unvented cylinder, give earthsave products a call (importers)
The system is 2 years old. From what i can gather the heating side of the system has been incorrectly installed so its no wonder not much thought has gone into the domestic side too. I thought unvented ecocents would have been a better idea rather than the vented with shower booster pumps!
Yes i am aware of principals with open vented systems just the ecocent isnt an ordinary vented cylinder, its not as easy as a vented cylinder you cant just add a tapping to the cylinder or so it seems anyway.
Ecowarm thanks for your input mate.
I have actually already spoke to their technical team who have said it is fine to have a vented cylinder just were unsure themselves to why someone woud install shower pumps to boost the hot water pressure when obviously the unvented system would suit the needs of the house. I think ill give them another call tomorrow though, Thanks again.
Dan what's 'ASHP'? Sozz but sometimes abbreviations do my headin! lol
If your demant outweighs your supply however then you'll get air drawn in eh? If that's something knew then you look for what's changed since installation IMHO:)
Reply to Ecocent vented cylinders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is unvented and pressurised. The cold water feed into this cylinder is from the attic tank, not the mains as I turned off the mains stopcock to see if hot...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably because of the set-up) but last year got so feeble that a guy suggested fitting a pump alongside the cylinder. This can work fine but then all of a...
1K
I have a vented hot-water cylinder that was installed when the house was built - 38 years ago! It has a header tank in the loft and the cylinder is located directly above the ceiling of a new and expensive kitchen. It does not leak and causes no obvious problems. Should it be replaced? Advice...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Hello, We hade a problem with our hot water not working in one of our bathroom's (all other outlets were working) Therefore we got the Thermostatic Shower Valve changed and everything was working again. However a few days later, both hot and cold no longer works for the bath and the hot...
