Discuss easy tap splitter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
both the same ones in a fancy case the others not
get a deep socket, ones that grip the flats of the nut 1/4'' drive.
then stick the impact driver in it ;)
make sure you hold the tap tho
I thought gasman was a heating technician, not a leaky lad, I try to sreer clear of old taps n plumbing myself.
So is it a worthwhile tool for those times you get in a fix, or is it a DIY thing that only works when you're not a plumber and the reason you can't get it undone is just that you don't have any strength or proper set of ring spanners or similar, and then breaks when the tap is REALLY stuck?
I.e. any good for professionals or not?
Can you justify the cost of purchase and how often would you use them ? Been doing this job since the seventies & never needed anything like this
Could someone invent something similar for removing bath taps from old enamel baths.
My angle grinder is prone to cause collateral damage.
hard work and alot of swearing but haven't failed yet :D hate them
Is the set useful ? Im thinking to get one does somebody use it at all ?
i'm going to buy one. does anyoe know of a shed/scrufix type affair that stocks them or is it random online stockists only?
Did a few jobs with my friend who's a plumber / gas man
Went to put tap revivers on, stuck fast, pulled out the old tool (!) & he was very impressed. In & out 15 mins.
Reply to easy tap splitter in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of a kitchen tap which requires the housing around the cartridge to be removed. The housing is much more than hand-tight and I was wondering if plumbers have experienced this type of tap and how the housing is removed without damaging it. Thanks.
The unit underneath has no access to the tap and from measuring, the unit does not even go as back as where the tap is. The pipework is a mess. I think the only solution is to remove the sink as I don't think my tapex kit will get to the tap bolts from cutting from the bottom with my multitool...
Hello I have a Franke Planar Kitchen tap and it’s got a leak. One drop per minute. I’ve been on YouTube and seen that there are grub screws to remove, first for the handle, then once that is off the square piece between the handle and the tap body to get the cartridge for replacement. I have...
I have a wall mounted bathroom tap that leaks. Presumably I need a washer of sorts replaced. I cannot work out which tool I need to remove the tap. There is a small hole (8mm?) to the side but I can’t seem to get a fixing from either a alum key or screwdriver. Ever hopeful…? Matt
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
