Discuss Dripping from boiler,condensation? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon,
My daughter has a very cold kitchen with no radiators and the heating to the rest of the house goes off at night.
This morning, after probably the coldest night of the year, once the wall mounted gas boiler came on it dripped onto the worktop about a quarter of a cup of water. The dripping stopped after a while and since then it has not dripped even though it is switching on and off during it's normal cycles.
Could it be condensation within the boiler when the room is very cold, as it is not happening once the house is warming up?
Thanks for your help.
You need a Gse probably a small leak inside get it checked out soon no water should drip out a small problems soon turns into big problems if it gets in the electrics regardsk
As above. There's nothing inside the boiler you are qualified to touch.
Get a gsr.
Thread closed
Reply to Dripping from boiler,condensation? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has been intermittently dripping from the hot tap, and the cold tap is squeaking when you turn it. Possibly two different issues, possibly related? The...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On further inspection I discovered that water was coming from boiler cupboard. On looking in boiler cupboard I found boiler has started leaking water...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
